Kubota L 39 antifreeze
   / Kubota L 39 antifreeze #1
nascamp
Kubota L39
Im going to change and flush the antifreeze, what should be used and what ratio mix ?
   / Kubota L 39 antifreeze #2
50/50
   / Kubota L 39 antifreeze #3
Kubota recommends Ethylene Glycol (green) for older units... I change mine every other year and flush with distilled water
   / Kubota L 39 antifreeze #4
If you purchase straight ethylene glycol antifreeze mix 50/50 with distilled water, not tap water. Caution, it is also sold pre mixed in which case you don't dilute at all. If you flush your system with water be sure to use distilled water. Tap water contains minerals you don't want in your system.
   / Kubota L 39 antifreeze #5
You do not list where you live.
50/50 is highly recommended and definitely use the
distilled water
willy
   / Kubota L 39 antifreeze #6
Keep in mind that the overwhelming majority of antifreeze / coolant for automotive use is ethylene glycol based. Standard Green (silicate), HOAT, OAT, etc are all predominantly ethylene glycol based with different additive chemistries. A distant second are the propylene glycol coolants, followed by more exotic coolants for racing applications.
Even though Kubota has historically stated in manuals to use "ethylene glycol type" coolant, that doesn't really mean much.
If doing a drain, flush, and fill Kubota small engines can take a wide variety of coolant types. Adding coolant is another matter entirely, and mixing coolant types is almost always a bad idea.
For the OP;
Your machine likely came with Standard Green silicate antifreeze. My last 5 Kubota machines did. I have always switched them out at the first service interval to an HOAT coolant (Zerex G05) for the 5 year maintenance interval, rather than 2 years for the Standard Green. Whatever chemistry you determine to be compatible, 50/50 with distilled water is what to shoot for if you buy concentrated coolant, or straight out of the container for pre diluted coolant.
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
2015 DODGE RAM...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
