Kubota L245 2-wd leaking around gear shift
   / Kubota L245 2-wd leaking around gear shift #1
RPETTY
I have an older Kubota L245 that has just started leaking fluid around the gear shift. I read elsewhere on the internet that it could be caused by a clogged "weep hole" . I cannot locate a weep hole anywhere.... Anybody have any suggestions? PLEASE HELP....
   / Kubota L245 2-wd leaking around gear shift #2
The weep hole is located on the left rear, upper side of the transmission just below/behind the seat as you sit on the tractor
Electric Mobility Scooter (A51694)
Electric Mobility...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50323)
Pitts Tri-Axle RGN...
Diesel Forklift (A51691)
Diesel Forklift...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2015 Freightliner M2 106 Ambulance (A50323)
2015 Freightliner...
