Kubota L2800 HST - extra hydralics at back
   / Kubota L2800 HST - extra hydralics at back #1
subzero
Bronze Member
Kubota L2800 HST
I want to add some extra hydralics on my tractor, either two or three spools .. what is the simpliest way.. I already have a loader, what is a power beyond kit, and how much $ are they ?
   / Kubota L2800 HST - extra hydralics at back #2
sub,
If you search on Power Beyond you will find lots of information. My non technical description is that if your loader control has power beyond, there is basically a port that you can tap off to take the hydraulics "beyond" to another control (can be in the rear) and set of valves. My guess is that your loader valve does have power beyond so you will need to decide how many remotes you want on the rear, buy a valve and pipe it in. I did mine last year and I found it to be relatively easy BUT, figuring out all the fittings takes a lot of time.
Here is a link to a thread that includes pics of my install - there are other similar threads out there. Search on Rear Remotes and you will find lots of information. Search this forum and the customization forum since there was not always a separate hydraulic forum.
http://www.tractorbynet.com/forums/...98-7510hsd-rear-hydraulics-2.html#post1045378
Hope that helps - good luck.
   / Kubota L2800 HST - extra hydralics at back #3
Check out this thread and also this thread.
Factory stuff is usually nice but for the L2800/L3400 Kubota has a generic set of remotes that bolt on to the ROPS. An aftermarket setup using the Prince SV valves that MadRef points to in the threads above is not much different and about 1/3 the cost.
One of these days I'll get mine done.
EZ-GO Freedom RXV Electric Golf Cart (A50121)
EZ-GO Freedom RXV...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
New LS170 Skidloader (RUNS) (A50774)
New LS170...
2015 Chrysler 200 Sedan (A50324)
2015 Chrysler 200...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
Cummins 7HGJAE-2132 Generator (A50121)
Cummins...
