kubota l3010 oil leak
   / kubota l3010 oil leak #1
grinder2
moncton nb
414 int /l3010 kubota
hello i have a l3010 kubota 4wd. it has started to leak oil at the front steering knuckle. anyone ever had to fix one of these . any thoughts would be great thanks
   / kubota l3010 oil leak #2
Grinder,
If you are still looking for information for your knuckle oil leak, contact Messicks.com. They will give you a parts breakdown sheet and you can order the seal assembly. If your L3010 is anything like my L3130, pretty straightforward in replacing the seal. Just need a couple of good large snap ring pliers as the snap rings are beefy.
Good Luck,
David
PS I put off replacing the seal as I needed the tractor for a job. Added oil the axle for 6 months or so. Just checked it every few days.
   / kubota l3010 oil leak #3
Since the OP is in Canada, maybe he should check with Paul Short for a good dealer to work with... I think Messicks may have issues with shipping parts to Canada, based on earlier posts, if my memory is correct??
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
2020 KUBOTA RTV...
