Kubota L3430GST Fuel shut off solenoid clicking on & off
   / Kubota L3430GST Fuel shut off solenoid clicking on & off #1
RP Motors
Kubota L3430
fuel shut off sol. clicks off engine stops, turn key off turn key on sol. clicks on & off and then it stops then I can drive it. this will happen 4 or 5 times as it warms up it gets better and then it stops clicking and I can run it for hours until next day it starts all over again . I replaced battery , all fuses , cleaned both fuse boxes , all grounds , poss. connectors . replaced fuel shut off solenoid
   / Kubota L3430GST Fuel shut off solenoid clicking on & off #2
They are known for filling w/ engine oil.. just remove it, depress plunger a few times & drain the oil out of it & see what that does..
When I installed the new sol. it took 4-5 min. to start clicking on & off , I will try that thanks
I fixed the problem it was the Timer opc switch , replaced it no problems since Thanks
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
2024 JOHN DEERE 6110M LOT IDENTIFIER 249 (A53084)
2024 JOHN DEERE...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2012 VOLVO ECR305CL EXCAVATOR (A51246)
2012 VOLVO...
2020 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2020 CATERPILLAR...
