Kubota L3830 shut down. Safety switch?
   / Kubota L3830 shut down. Safety switch? #1
Bowhunterman
Lindale, texas
Kubota l3830
Mowing fine then it just shuts down. When I try to start the dash says. HST then Neutral. Makes no effort to crank. Any ideas?
   / Kubota L3830 shut down. Safety switch? #2
Not sure why your shutting down. The hst error sounds like you hst petal needs to be adjusted.
How do I adjust the pedal? And how do I know when it is properly adjusted?
Ok. The pto light is on when the key is on. I'm assuming it may be the pto safety switch. Will try that. It appears that there r 2 little switches. Would wiring each separate side together work?
Checked fuses. Turned out to be a stupid 5amp key stop fuse! Plugged in a new one and pto light went off. Cranked right up. Hope this helps someone.
   / Kubota L3830 shut down. Safety switch? #6
Thank u!
   / Kubota L3830 shut down. Safety switch? #7
Thanks for the post. Worked on the Kubota 3130 also. $2.89 for box of fuses vs hundreds if a tech had to come out.
PT 8' x 18' 4-Wheel Wagon (A47307)
PT 8' x 18'...
2012 Ford Focus Sedan (A46684)
2012 Ford Focus...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A46683)
2025 78in Dual...
2019 Hyster H50XT Forklift  Rugged and Ready for the Job Site! (A48561)
2019 Hyster H50XT...
2015 LEDWELL LW48 HTHT2 48FT  HYDRATAIL TRAILER (A45677)
2015 LEDWELL LW48...
2018 FREIGHTLINER CASCADIA SLEEPER (A45677)
2018 FREIGHTLINER...
