Kubota "Loader" cylinders leaking.
/ Kubota "Loader" cylinders leaking. #1
don716
North Georgia
Kubota/ B7500/with 2000 lb winch
I have a B7500 with a LA302 loader and the "lift" and "dump" cylinders are leaking. Can someone point me in the direction on some rebuild kits for these cylinders? I checked with my local dealer and he can get the whole cylinder at over 400.00 each. I told him I needed the cylinders not a tractor.lol He told me he could rebuild them for 100 bucks each. Nothing more than some O rings and a few other small parts. If I can buy the kits at a reasonable price I think I can do the rebuild myself. Who has these kits at a good price? Thanks
/ Kubota "Loader" cylinders leaking. #2
Have you tried Messick's. Maybe a local hyd. repair shop can get them for you.
My Kubota dealer has ordered cylinder kits for me in the past. Not much money either. I think $26 for the PS cylinder.
/ Kubota "Loader" cylinders leaking. #3
My local NAPA parts store does all types of hydraulic rebuilds. I am sure they sell the parts, although perhaps not in kit form.
Perhaps your local NAPA can provide same.
/ Kubota "Loader" cylinders leaking. #4
I have always heard that called a packing kit. Be sure you can break the nuts loose that hold it together. They can be tight! If you get it apart you can usually take the seals to a hydraulic shop and they will have seals to make you a packing kit.
/ Kubota "Loader" cylinders leaking. #5
Do they leak badly?
,,,,The ones [original] on our L2550 drip a little. Have for years. It stays outside and total makeup is no more than I attribute to the auxiliary QC disconnect dribbles. I have better things to do than worry about those minor losses costing me a dollar or so per year.
/ Kubota "Loader" cylinders leaking. #6
I had a leaking cylinder on my loader a year ago. I checked around for parts, and looked at what it would take to remove the nut without destroying the cylinder. After checking on prices for the parts, and the proper tools, I took the cylinder to my Kubota dealer. They rebuilt the cylinder for about $130, and had it ready to go in just a couple of hours after I dropped it off. Had I done this myself, I might have saved 50 or 75 dollars...but I could have easily screwed it up, and been out $400 for a new cylinder. I am all for fixing things myself, but I also know when to let a pro handle the job. A year later, and it is still working great.
/ Kubota "Loader" cylinders leaking. #7
I just had 2 of the 3 repaired on my BX2200. I had a local shop do them and they were about $125 ea. On both of them, he did hone the cylinders to repair some minor scratches.
/ Kubota "Loader" cylinders leaking. #8
If you want to do it the wrong way, then use a big pipe wrench on em. The big ugly grip marks make it more manly!
/ Kubota "Loader" cylinders leaking. #9
I remember when I rebuilt my front loader cylinders that I took one of each pair of cylinders apart, drained the fluid, then took the cylinder to a hydraulic shop, they found the seal kits for the rams, forgot how much but was kinda inexpensive. Rebuilt my cylinders, bled the air out of the system. Just a messy job.
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
New/Unused SD Lanch Mobile Crusher (A61166)
New/Unused SD...
2022 Mercedes-Benz Sprinter 1500 Cargo Van (A61568)
2022 Mercedes-Benz...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
