Snowblower Kubota / Lorenz Snowblower Question
   / Kubota / Lorenz Snowblower Question #1
etgjr
U.P. of Michigan
Kubota 4330HST, 853FEL
I have a Kubota 4330HST w/loaded tires and FEL.
I'm looking at a lightly used Lorenz 734 snowblower. It is rated to 100hp, is 84" wide and 1100lbs. The center of mass is about 2.5 ft from the lift points. Cost is $2500.
I think my tractor can lift it. Kubota specs allow for 1040lb box blade which I figure has about the same center of mass. I think I'm right at the weight and HP limits for the tractor. What do you guys think, to much blower or am I ok? What about the price?
Thanks,
Ed
   / Kubota / Lorenz Snowblower Question #2
Ed how big is a 4330? I ask because I own a Lorenz 630 which is 78" wide and weighs 560 lbs. I run it on my Branson 4020 40 hp turbo. Its just the right size for my tractor. I think the 734 is alot of blower but if your Kubota can handle it then go for it. Thats a real good price and these Lorenz units rock. /forums/images/graemlins/grin.gif
Thanks for the reply Snoboy,
I bought it. The guy used it to blow out about a 1/4 acre area for 4 years. Its in great shape. My Kubota weights in at 6200 lbs with the loaded tires and the FEL on. The 3 point is rated to 2760 lbs 24 inches back from the attachement points. I think I'm ok.
Our snow is melting fast, I have to get it hooked up and see how it does!
-Ed
John Deere 970 Cultimulcher (A52128)
John Deere 970...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
Kubota SVL 95-2s 14009 SKID STEER (A50322)
Kubota SVL 95-2s...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
