Kubota M 6800 loss of power
   / Kubota M 6800 loss of power #1
HCJtractor
Veteran Member
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
My 10 year old Kubota starts to loose power when the fuel level gets to about half a tank. It begins to run as if it's about out of fuel, but then when I add diesel, it only takes around 5 gallons to fill it to the top. Once I fill it, it runs fine. But run it back down to about half a tank, and it sputters again. My gauge also seems not to be accurate, but not sure if that's related, nor is that a big issue. As long as I keep the tank pretty full, I have no issues. Is this a fuel pump issue, or something wrong with the fuel pick up in the tank?
Sent from my iPad using TractorByNet
   / Kubota M 6800 loss of power #2
not a clue about your specific tractor. just thinking out loud of what i might check.
fuel filter clogging
screen maybe in fuel tank
fuel shut off valve not all the way open or rather barely open
vent in fuel cap plugged.
fuel pump issues.
   / Kubota M 6800 loss of power #3
I owned a M4900 that acted similar to your tractor. I found a plugged tiny screen in the fuel shut-off valve on the water separator. I removed the screen and engine stalling problem was resolved.
Thanks guys. That makes sense. I'll check that.
(null) = (null);
(null) = (null);
(null) = (null);
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
Super Material Lift MH1000 (A53472)
Super Material...
