Kubota M Series Plastic Hyd/Tran fill plug
   / Kubota M Series Plastic Hyd/Tran fill plug #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
Looking for the Plastic (Nylon)? Cap,* that is used* to seal Hydraulic/Transmission fluid reservoir fill port it is located at the rear of tractor slightly above the PTO Cover (Shield).* I can not locate it in the Kubota illustrated parts list Online, mine has been cross threaded.* I do not know what Kubota calls this threaded plug* in the Operators Manual it is referred to as a Oil inlet. ??*
Looking for a part number AND what Kubota Calls this item ?*
Is there an alternative that I can use for replacing this plastic cap Wouldn’t a metal Cap not be so easy to cross thread ?
Is there a fix for this ? Thanks
   / Kubota M Series Plastic Hyd/Tran fill plug #3
Hopefully it's as simple as you'll be more careful in the future to not force a cross thread to the point of damaging the plug. :thumbsup:
It's equally "easy to cross thread" that hard nylon plug as a metal one, the difference is your not going to damage the internal female threads on the tractors rear with a plastic plug. Now if someone would come up with a way to remind someone (ME) to put the fuel cap back on the tank.......:laughing:
Thanks for the response, Just so you know I am not an idiot most of the time, This is a tractor I bought recently I got a great deal on. The former owner cross threaded the plug . I didn't notice it till I was getting ready to do a 600 hr Hydraulic/Transmission fluild & filter change. I was able to reinstall the plug by very carefully threading it back in But takes to much time. I found the part numbers and order a one to make my life easier. It's a real pain to R&R the filters without removing the rear tire. Thanks again for the reply. PS all my other tractors and I have had quite a few (retired excavating contractor) all had metal plugs never had a problem with them.
   / Kubota M Series Plastic Hyd/Tran fill plug #5
10-4 case! I was concerned that you might not have been the one that cross threaded it and tried to be gentle, although I have lost a fuel tank lid and forgotten to put it back on a time or two.:D
NO Problem
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
PALLET OF (2) THERMOKING TRIPAC UNITS (A50854)
PALLET OF (2)...
John Deere 693 Corn Head (A50514)
John Deere 693...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
