Kubota M5700 Hydraulic issue after oil change
   / Kubota M5700 Hydraulic issue after oil change #1
Rex-man
Kubota M5700
just changed the oil and two filters on my Kubota m5700, used the Kubota filters and the Kubota Super UDT oil, went to start it up and no power steering, loader won't work and 3 point will not lift. Wondering if there is a way to bleed the pump.
   / Kubota M5700 Hydraulic issue after oil change #3
Sounds like the filter is not on properly and is sucking air. Make sure gasket is seated properly, filter is tight enough, maybe you'll have you take the filter off and inspect gasket for damage.
   / Kubota M5700 Hydraulic issue after oil change #4
I would be looking at the filters, particularly for missing or doubled up gaskets. It happens.
   / Kubota M5700 Hydraulic issue after oil change #5
HST? Does it move?
You topped the hydraulic fluid after changing the filters?
   / Kubota M5700 Hydraulic issue after oil change #6
Common issue with Kubota tractors (all models) is the filter gasket sticking to the filter boss on the gearcase casting and then you put on a new filter and the old gasket and the new filter gasket against the old one compromises the seal and if the pump sucks any air (from the double gasket), it looses it's prime.
On my M9's it hard to see of the old filter has left it's gasket stuck to the gearcase as the filters are up, underneath the operators station so you need to physically look at the removed filter to see if the gasket came off, or 'feel' the gearcase boss to make sure the old gasket wasn't left behind. It even states that in the owners manual, least mine does.
Because both my M's hold a lot of fluid (almost 15 gallons each), draining them can be a real mess, no ordinary drain pan works, so what I did was, I went to the scrap yard and bought an old aluminum truck fuel tank (you can use steel or aluminum) and I cut one end off with about a 12 " high wall and I drain my fluid into that. Handles the mess quite nicely. Welded handles on each side too (optional) and I siphon the used fluid back into the 5 gallon pails the new fluid came out of and 'donate' them to my dealer, he has a waste oil burner in his shop.
   / Kubota M5700 Hydraulic issue after oil change #7
Had the same issue today, turned out to be a priming issue, under the pump on the suction line is a small Allen screw, I backed it out and got some air out of it, tightened it again, started the tractor, repeated this 2 times while turning the steering wheel it primed.
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
71066 (A49346)
71066 (A49346)
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
New Holland B95 Backhoe (A50490)
New Holland B95...
