Kubota M6800
/ Kubota M6800 #1
CAH2873
Hello- I have a Kubota M6800 2wd that has an issue with the 3pt Hydraulic Lift. When I move the lever all the way up, the arms come up and then it binds up as if the relief valve does not kick in. I then move it slightly downward until the noise quits. The problem with this is that having a box blade on the back of it and when I lower the lever down to the neutral position, the implement will drift downwards. Can anyone help me out on how to correct this issue?
/ Kubota M6800
Just went and look at the Feedback Rod. It is broken in half. Need to get it replaced.
/ Kubota M6800 #4
Squealing when 3 pt is fully raised sounds typical when feedback rod needs adjustment
this is TBN forum working at it's best, an informative reply that quickly solved the OP's thread w/o diversion.
good to see this at work, good luck w/the repair
Dump Body (A61568)
Dump Body (A61568)
2017 Ford Escape (A61569)
2017 Ford Escape...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
KBH Tender (A63118)
KBH Tender (A63118)
1985 Ford Ltl9000 Tender Truck (A63118)
1985 Ford Ltl9000...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
