Kubota M7040SUDH Hydraulic Pump
   / Kubota M7040SUDH Hydraulic Pump #1
waggy5
New York
Kubota M7040 & B2320
Hi, does anybody know how to modify a Kubota M7040SUDH tractor's hydraulic system, specifically the hydraulic pump? the existing 11 gpm pump if far from adequate! the 3pt lift and loader just does not cut it. Thanks!
   / Kubota M7040SUDH Hydraulic Pump #2
Subscribed. I don't think you can do anything to increase gpm. You can increase pressure though.
   / Kubota M7040SUDH Hydraulic Pump #3
Maybe JJ will see this and chime in. He could give you all the reasons why or why not to try that. He could also give you a technical idea of the gains you could possibly make.
These are dangerous waters you are treading in. Misguided adjustments will surely lead to failures that might be very expensive.
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
48" Pallet Forks  (A52384)
48" Pallet Forks...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
LOT LOCATIONS (A53426)
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
