Kubota manual spec for oil vs what Kubota dealer stocks
   / Kubota manual spec for oil vs what Kubota dealer stocks #1
beowulf
Veteran Member
Central California Foothills
Kubota L3410 HST, J Deere riding mower
The manual for my L3410 lists 10W-40 as the recommended oil. However, the local Kubota dealer only stocks Kubota 15W-40. They advise that is all they ever stock and recommend that. Comments? I bought the 15W-40 and will be putting that in today. Thanks for any input. Just curious.
   / Kubota manual spec for oil vs what Kubota dealer stocks #2
If you're in California I would think that the 15w40 is good. The first number is for the flow on a cold engine and I don't think that it gets very cold where you are?? So a 10W or 5W or a 0W should flow easier then a 15W on a cold start. You should be good...although I'm not sure what the coldest temps could be where you live. Dutchy
   / Kubota manual spec for oil vs what Kubota dealer stocks #3
That's all I ever use. Kubota 15W40.
Thanks Dutchy. Good to know. The tractor service guy was just here - checking on a few things that needed attention, and he said he uses 15w40 in the tractors he services.
I am in the central California foothills and it does get cold at times, but not often and only a few times a year. e.g., sometimes might get below 32 overnight in the Winter and rarely lower than 25 in early mornings, and I am not using the tractor at those times.
Thanks again.
   / Kubota manual spec for oil vs what Kubota dealer stocks #5
Nice climate!! A good 15W oil would still flow fine at 0F or even colder on a cold start. If it still bothers your conscience, ask for their synthetic next time around, and then you'd be covered for the extreme heat or the cold mornings. Dutchy
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2015 CASE 580N (A47477)
2015 CASE 580N...
Kubota BX2230D (A47384)
Kubota BX2230D...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
