Kubota rear remotes
   / Kubota rear remotes #1
HalDew
New Brusnwick, Canada
Kubota GrandL 3130
Hi. my first posting. I have a Kubota GL 3130 with one factory insatlled rear remote. I would like to add a TNT plus perhaps angle for my rear blade. Is theer an easyw ay to expand the one remote to add more outlets?
   / Kubota rear remotes #3
The easiest way is to use the Kubota valves. Since you already have the first one installed, You need two more valves at $200+ each and a second and a third position stack kit, again $200+ each. It is a bolt up job. The stack kits come with the necessary bolts. It will be the easiest to do if you remove the right rear wheel and the right side lower 3pt arm. Let's you get up close to where you will be working.
It is also neater using the Kubota valves. By the way the remotes are dealer installed items when bought with the new tractor.
Vernon
Unused Delta Crash...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
Two Engines (A50325)
