kubota rtv 1100 snow plow
   / kubota rtv 1100 snow plow #1
thepits
canfield ohio
Kubota BX25
Just bought a new Kubota rtv 1100 with a snow plow. The only thing I have to unplug the bed lift to run my plows power angle. Is their a way to set up so I can run the dump bed and the plow at the same time? i'm totally new to all this. And all I was told is I could buy a tee fitting for the hydralics to run both but the control for the dump bed also angles the plow. Can I get any info on how to fix this?
thepits
   / kubota rtv 1100 snow plow #2
There are electric valves that you can buy where you plug in one and you get two sets coming out that are switched electrically as to which one is being used allowing you to have both ready at the flip of a switch.
thanks Art it sounds like just what i'm looking for. Do you know who makes these valves? or what they are called so I can chedk locally and maybe find them.
   / kubota rtv 1100 snow plow #4
Fasse makes several versions of the electric diversion valves. I have one on my JD 4320 for the 3rd function on the loader, works sweet.
Todd
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A50854)
KONE CRANES...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
Unused 2025 CFG NT18K Mini Excavator (A49461)
Unused 2025 CFG...
