Kubota RTV900 breaking snap ring on rear wheel prop shaft
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #1
Rowdius
Nugent, Texas
Kioti CK35 With KL130 Loader
We have two 2010-2011 RTV900-G9s that have held up remarkably well for the past decade considering undergrad and grad students have used and abused them while doing wildlife research. In the last year, both of them have started having the snap ring on the rear wheel prop shaft begin breaking, causing the seal to leak, and sometimes chewing up the bearing if the grad student doesn't notice it in time. Seems to happen every 6 months to a year. Again, it's happened on two different machines, both of which have never had that problem in the previous 10 years.
The only thing that has really changed is that we're now on a sandy ranch with tons of shin oak (1 - 3 ft tall oak shrubs). But I'm not finding sand or sticks inside the seal when I tear it apart. I would seem to me that it would take quite a bit of lateral force (like sliding sideways down a slope or something) to do this, but I don't have evidence of that happening.
Anyone experienced this before, or have some ideas on what is causing it?
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #2
Mine is doing the same thing. It doesn't make sense why the retaining ring keeps busting. Wish someone had a solution.
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #3
Was this the same issue with the rtv that someone solved by tightening up the worn suspension to decrease the lateral force being generated by worn suspension component (s)?
I can’t remember, I think I read it on this forum…
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #4
I will take a look at my suspension and see if there is any lateral slack.
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #5
I wish I could find the discussion, it was snap rings or maybe axle walking out….
Let us know what you find
   / Kubota RTV900 breaking snap ring on rear wheel prop shaft #6
Sorry for the delay....
I couldn't find mine to have any lateral slack. I tried a different external snap ring, put everything back together, and it has been working for a couple weeks now. I have been careful to keep it on mostly level ground though. If it happens again, I'm thinking of filing a deeper groove where the snap ring goes so it's not as likely to pop off.
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
UNUSED RAYTREE RMLS18T 109 SPLITTER (A51248)
UNUSED RAYTREE...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
1991 Ford LNT9000 Truck, VIN # 1FDYW90L5MVA15646 (A51572)
1991 Ford LNT9000...
