Kubota too Gravley Mod
   / Kubota too Gravley Mod #1
guppy
I have a Kubota B-5100,and a small Gravley shaft drive Tiller.I can modify the tiller too 3PTH with no problem,But should I weld a slip clutch on the shaft to protect my PTO from getting damaged.If I jam a rock in the tiller could this hurt the internal PTO drive? Thanks
   / Kubota too Gravley Mod #2
I wouldn't weld it, but if you can bolt a slip clutch on that would be best.
Ron
I have a square shaft on the gravley,and a round, off the pto,
   / Kubota too Gravley Mod #4
Keep us posted on how it works out. I have a Bolens cat 0 tiller I'd like to mount on my BX20...
   / Kubota too Gravley Mod #5
What if you went to TSC and bought a spline adaptor. Male side matching your tractor. And slide the female end over the gravely square shaft and welded that? Then you could just couple the slip clutch to the tiller. Etc, Etc. That way the slip clutch could possibly be used on other attachments also?? Just a thought.
Dave
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
M & M Grain Drill (A50515)
M & M Grain Drill...
