Kubota V2203 Engine Alternator, How many poles?
   / Kubota V2203 Engine Alternator, How many poles? #1
lear60pilot
Midland, VA
John Deere 4005
I have a Kubota V2203 engine that has a DENSO 12 volt Alternator on it. I am using this engine in a generator application and am wiring a Tachometer into the alternator. I need to know how many poles this alternator has to set the dip switches correctly. I have looked all over the internet and I can't find this information. The Alternator is just like this one
Alternator Kubota Generator Sets KJT210V Kubota V2203 Diesel 40 Amps | eBay
If any one knows that would be greatly appreciated.
Thanks!!
   / Kubota V2203 Engine Alternator, How many poles? #2
May be a bit difficult to find. Since the poles are in multiples of 2, I would run the engine at a speed that yopu can estimate to the nearest 100-200 RPM and then try the settings until you hit the right RPM. One step either way will be off by 2:1 so you should be able to judge it.
paul
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
