Kubota will not move
/ Kubota will not move #1
GB007
Have a 23 HP diesel tractor; plate shows it is a L2500D. Tractor is not moving or very slowly if at all. Prior it would make a screaching sound as it ran. Engine is fine. Can see the threaded spline moving in hydraulic box until tractor stops then it does not move and squealling noise sometimes occurs. any suggestions??
/ Kubota will not move #2
GB007 said:
any suggestions??
It would help to to know which tractor you have.
The plate indicates L2500D
/ Kubota will not move #4
Brakes on? Brakes locked up?
Clutch burned out? Does squealing stop when you depress the clutch? When you let the clutch out, with the tractor in gear, what happens. You should hear it tax the engine a tad and then start moving.
I'm not sure what you mean byt the threaded spline, do you mean the pto shaft? Disengage pto and see what happens.
/ Kubota will not move #5
Sounds like you have clutch problems. The clutch disk could be down to metal and it is eating the flywheel and pressure plate up.
John Deere 1025R (A62177)
John Deere 1025R...
JOHN DEERE 1210A GRAIN CART (A64277)
JOHN DEERE 1210A...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
