I just purchased a Kubota Z620 from Japan to install in a Garden tractor. The engine appears to be in good condition and I'm setting it up for a test run. One odd thing about this engine is that it has NO thermostat or water pump. Just the upper radiator hose connection. I know the old John Deere tractors used thermal syphon cooling, is it possible this engine does too? Where you would expect the water pump to be is where the dynamo (alternator) is located. Also the hose fittings are much larger than the ones on my Z430's. Your thoughts would be appreciated as information is very limited.
Thanks,
Chris
Thanks,
Chris
