Kuhn L32 rototiller-need help plz
   / Kuhn L32 rototiller-need help plz #1
jmdrewme
Kubota B7800
Hello all! This is my first post but I have gotten alot of questions answered just by reading. Anyway, I put my tiller on my B7800 Kubota tractor today to do the fall tilling. I tilled my neighbors garden with no problem. When I started tilling mine, it worked fine at first. Then it got loud and now it won't till into the ground. The blades turn fine until I drop it to the ground to work. I checked the chain case and can't see any oil. My question is what kind of oil do I put into it? Should I check the gearbox if I can get it to open? Thank you in advance.
   / Kuhn L32 rototiller-need help plz #2
I'd lay odds on it that the slip clutch might be loose!
Thanks art. Now can you tell me how to check it?
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
2004 Sterling Tack Truck (A52384)
2004 Sterling Tack...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2006 Hummer H3 (A51694)
2006 Hummer H3...
