Kutoba bt650B backhoe won't swing
   / Kutoba bt650B backhoe won't swing #1
rox1390
I have a Kubota B20 with a bt650B backhoe. The backhoe will not swing. I think the computer has gone out. How do you convert the backhoe to manual operation and by pass the auto return function and computer? Is there a replacement kit available?
   / Kutoba bt650B backhoe won't swing #2
Rox,
There used to be a kit to convert the electrohydraulic swing back to manual valves but the parts are long gone.
Bes tbet is to change the complete backhoe valve out - I would suggest getting a used valve unless you make you living every day with the B20.
Good luck!
   / Kutoba bt650B backhoe won't swing #3
try unpluging the connectors at the control box that is what I did to mine several times when I had it there is a way to bypass also but I can't remember what it is now ??
   / Kutoba bt650B backhoe won't swing #4
Just bought the conversion kit $700 from Kubota. Well worth it. There are still a few out there check with your dealer.
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
377811 (A48836)
377811 (A48836)
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
