Tires L-3700su front wheel alignment, + camber, pulls to right
   / L-3700su front wheel alignment, + camber, pulls to right #1
buttstock
Maine, ayuh
Kubota 3700su
Bought used, has 575 total hours, Kubota L series 3700su 4wd. Took tractor down the road in "high" gear, at ~2000 rpm to help out neighbor. Tractor front end pulling hard to the right. Front tires have equal 50 psig. Noticed right front tire has positive camber ( lower part of tire is "more inside" than upper part of tire,or in other words, if I dropped a vertical line down from the top outside of the right front tire, the line-where it hits the dirt, would be about 1 inch AWAY from the outer lower part of the tire.). Don't notice much "toe in" on the right front tire, maybe a little ( "1/4" ?). I have not had both front tires off at same time while jacked /supported up to measure width across of front and rear of front tire hubs. No wobble to tires. Rotates "straight."
I have never noticed this hard pulling to the right in the limited use on dirt on my property ( 35 hours since I bought it?), but really felt it "on the road." I road the crown of the paved road a ("level ground") to see if I still had the hard pull to the right-and I did.
What is going on? Both front tires are the same make and size, and as stated, at equal pressure. All 4 tires are R4 design. This is my first tractor ( not an expert).
Any thoughts? Do not hear any noise of growling. Tired are in good shape (<600 hours). The 3700 was made from 2010-2012, and has a 37 up 3 cyl diesel, hydrostatic tranny.
Help. How do I get rid of this hard right pull to the right, and positive camber?
   / L-3700su front wheel alignment, + camber, pulls to right #2
If the left front tire/wheel doesn't have the same positive caster as the right front on a level surface,I would be thinking something may be bent?
Interesting! Keep us posted.
Good Luck!
   / L-3700su front wheel alignment, + camber, pulls to right #3
I have the same tractor. Can you post some pictures of the front end ?
Long 1537 Rototiller (A47809)
Long 1537...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A46878)
2021 John Deere...
2013 UTILITY 53X102 DRY VAN TRAILER (A43005)
2013 UTILITY...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A46878)
80in HD Tooth...
Trash Combo Trailer (A45336)
Trash Combo...
1992 FORD LT9000 DUMP TRUCK (A43005)
1992 FORD LT9000...
