L 4330 50 hour service
   / L 4330 50 hour service #1
teddydo
Mississippi
4330 Kubota, 600 ford
I changed the engine oil /forums/images/graemlins/crazy.gif and was not sure where to drain the transmission and lift oil /forums/images/graemlins/confused.gif. And where to put it back it at. I am not good at looking at the manual picks. Would someone please be nice enough to tell me where to drain and refill. Thanks in advance,,,,,,teddydo
   / L 4330 50 hour service #2
I just finished the 50 hour service on my L3130 and the layout is the same.
I would be sure that I had 3, 5 gallon drain pans. I got the open top ones from Wal-Mart. The procedure I used was to loosen the hydraulic filter first. It will be on the left side under the operators platform. You will be able to drain about 5 gallons there. In the center of the transmission a little further back will be a large drain plug almost an inch across. Drain that next and you will get about 4 gallons. Last, at the inside bottom of the final drive to the rear axles will be a drain plug on each side, 14mm if I remember correctly. The filler plug is up behind the top link bracket. You will need a funnel with a long tube, about 18" long. The manual drawings are fairly clear so take a look at them.
Vernon
2006 Intellistrobe AFAD Trailer (A52377)
2006 Intellistrobe...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
