L1500 Kubota slack/play in the steering
   / L1500 Kubota slack/play in the steering #1
Garyp
I found the adjustment on the right side at the base of the steering post just below the fuel tank. Now I am wondering where it gets its lube. I see no zerk fitting. Ia amtold that most part for a 175 will fit the L1500/ Anyone know what lubes the steering gears on a L1500 or a 175? Thanks
   / L1500 Kubota slack/play in the steering #2
Should be 90w gear oil. Let me look.
Well a picture I have doesn't show much. Basically you fill it like a diff, remove a plug, add oil until it runs out, replace plug. On my 2500 it's .18qts, not much. Manual does show to use UDT or SAE 80, 90w oil. I would stick with 90w, heavier incase the seal is leaking a bit.
Rob
   / L1500 Kubota slack/play in the steering #3
And if the seal really leaks.. try a 0 or 00 pourable grease. Jd cornhead or other similar 'flowable' greases will work good for those applications.. as they slump back down into the cavity after the gear moves..
Soundguy
2012 BIG LOW BOY 130BBL VACUUM TRAILER (A53843)
2012 BIG LOW BOY...
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
ALLEN TRUSS SCREED (A53843)
ALLEN TRUSS SCREED...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
