L1500 lift question
   / L1500 lift question #1
Anonymous Poster
Epic Contributor
Still trying to figure what all the controls do,My lift is locked
in position and want lower even with me on it.It worked fine
before.Is there a locking lever somewhere?
   / L1500 lift question #2
Chuck
Did you get the diff lock answer?
There is a knob in front of the seat which can lock the lift. Also controls the rate at which it lowers.
Have a fiddle with that.
   / L1500 lift question #3
The hydraulics usually lock if the button under the seat is turned. We have even seen them so loose that they can turn with the vibrations of the tractor. If this is locked it takes maybe several turns anticlockwise to open it. The implement should then lower. And as Neil says, you can adjust the drop speed with this button.
   / L1500 lift question #4
Hey Bill, I've been away (Melbourne)
Come back and you are registered. Good to see.
Cheers
PS - Now if I get to Sydney I'll hold you to those free weights !!! /w3tcompact/icons/laugh.gif
OK Neil,
as I said if you can carry them you can have them.
Just a bit concerned your knuckles would be touching the ground by the time you got home (lol).
BillK
   / L1500 lift question #6
Some people say they already do /w3tcompact/icons/laugh.gif
Cheers
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
2021 John Deere XUV835M Gator (A50514)
2021 John Deere...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
Year: 2018 Make: Infiniti Model: QX60 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2018 Make...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
