L175
   / L175 #1
Dougandlindsay
Kubota 175
I have an older l175 I recently purchased. Thinking it will be easy to find a loader. NOT!!!! So now I’m looking for an older inoperable l175 with loader. Then I would have spare parts also. Came across a 7000 kubota. Will the loader fit and work on my l175? Anyone know where to purchase a loader for this machine? Or suggestions on what will actually work? It does have the hoses for a loader.
   / L175 #2
I had an L175 DT (4WD) with a loader and backhoe, and the L series loaders in the 80's vintage tractors are the same frame typically - (L175 L185 L245 tractors) but the B series B7000 B7500 is a smaller frame tractor and may not fit.
On my L175 it had a front mount pump off the engine for the hydraulics - do you have that pump and hoses or just the tractor Hyd Pump for the 3PT? It may not be enough for a loader..
A used loader is going to cost $1-2K and a new one 4-5K . You would be better off finding either a donor machine as you mentioned of the same size, or a bit newer tractor/loader combo and selling yours.
These machines can lift a good amount, and without power steering can be a chore to work in small areas. Then plan on replacing hoses and seals in the cylinders on the older vintage. I did all the cylinders, seals, and hoses when I restored mine.
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A46684)
2007 Ford F-150...
2 Yard Skid Steer Trash Hopper (A46502)
2 Yard Skid Steer...
2019 Falcon RME 4-Ton 16ft Asphalt Hotbox Dump Trailer (A45336)
2019 Falcon RME...
2025 Safety Basket Forklift Attachment (A46683)
2025 Safety Basket...
26x25 Rim (A46502)
26x25 Rim (A46502)
IH Super M Farmall Tractor (A46502)
IH Super M Farmall...
