L2195 Shear Bolt, PN 70060-04440
   / L2195 Shear Bolt, PN 70060-04440 #1
moship
Veteran Member
PA
Kubota L3130 HST 4x4 Kubota L4740-3 HST
Can someone verify if the shear pin, PN 70060-04440 used in a L2195 snow blower is a conventional 5/16" grade 5 bolt or one with a reduced diameter to control the shear point.
I called Messick's and they don't have any in stock to confirm the design and the closest one is located in TX and I'm in PA.
On line resource didn't have enough description or picture to verify the design.
After consulting online parts diagrams, the same shear bolt is used on the following?
L2173
L2174
L2175
L2195
L2674
Anyone have one of these blowers and can check the shear pin design?
Thanks for the link. After reading the entire thread it was not definitive what snowblower that person had and the length was longer in the thread that mentioned the neck down. 2.25" versus the. 1.75" for the PN I need.
Thanks again for the effort.
   / L2195 Shear Bolt, PN 70060-04440 #5
If desperate, how about sticking a grade two bolt in it, while you wait for the correct shear bolts from Messicks or Barlows or someone who can get them? Failure should be an option.
Varmint, I'm not desperate. Just trying to verify the design since I bought the blower used and don't have an owners manual to reference. I figured with all the users on here someone could verify since they are in very short supply from the dealer. Thanks
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
