l245dt battery charging problem
   / l245dt battery charging problem #1
jebah
My l245dt is apparently not charging the battery when I operate it. I have a good battery that holds its charge for many starts but if I run my electric winch the battery becomes quickly depleted. Does anyone have any recomendations on what I should try first to solve this problem?
   / l245dt battery charging problem #2
My 245 is showing charging but chg lights stays lit....have a new battery that holds one heck of charge, so not sure if regulator is bad, trying to find my lost service manual..... /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / l245dt battery charging problem #3
Greetings, I don't know anything about the l245dt, specifically whether it has a separate regulator or if it's built in to the alternator/dynamo but most all charging systems work using the same in basic principles.
Have you read the voltage across the battery with a volt/ohm meter with the engine off and then compared it to the reading when the engines running?
With a good battery, you should see around 12 to 12.5 VDC with the engine off and from 12.8 to 14.5 with the engine running. It should always read higher w/the engine running.
If it reads the same or lower than your charging system isn't working.
Check for blown fuses, loose alt belt and make sure all the elec., connetions are clean & tight. A loose battery terminal may start the engine but vibration from the running engine can keep it from making connection for chargeing.
Also, it could be that the winch you are using is pulling more current than your alt/reg can produce. If this is the case then the battery will discharge every time you use it.
Most tractor's charging systems produce around 15 to 20 amps @12VDC. You may check to see what your tractor's output specs are and also what the winch draws.
Sometimes you can get a high output alternator kit too.
Good luck
Volfandt
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
