L2501 50 he service
   / L2501 50 he service #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Reading past posts I see people doing more than an oil change at 50 hrs?
I read that people are also doing hydraulic filters as an example?
Maybe they have hydrostat, my tractor is manual shift.
My owners booklet doesn't specify this at 50 hrs?
Also I read there are two drain plugs for oil? I don't have tractor in front of me to look at.
Can someone give me a rundown of what I should be doing at the 50 the mark?
   / L2501 50 he service #2
The manual says change the hydraulic & HST filters but not the hydraulic oil. If you put a shop vac over the fill port & turn it on, you wont loose any oil other than what is in the filters. Some change the oil, bit I stuck with just the Kubota recommended filter change on both my machines.
I assume it was both engine oil & engine oil filter at 50, but dont recall. A lot less engine oil than hydraulic oil to change & it gets contaminated from blowby.
Thanks, I didn't have hst. Can someone tell me if there are 2 drain plugs
   / L2501 50 he service #4
Yes there are two. Oil pan has a hump in it for the front drive shaft, so its got two plugs. Drain the bulk out with the first and open the second to get the rest (like one qrt).
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2007 DOOSAN G80 GENERATOR (A52472)
2007 DOOSAN G80...
2000 KENWORTH T800 (A52472)
2000 KENWORTH T800...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2009 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2009 PETERBILT 389...
