briman
i got the service manual and ran pressure test here are the results p5=75psi, p6=450psi , p3= 450psi p4= 450psi service manual states fault in either modulating valve or gate valve .. i removed side cover to find problem but do not see any thing wrong i took modulating valve apart , no bad o-rings springs look ok . alittle leary to take gate valve apart but dont know if its servicable or you have to replace whole assembly.. originaLLY I PUT A NEW CLUTCH INIT BUT THAT WASNT THE PROBLEM .. COULDNT GET TRACTOR TO MOVE SO I TOOK THE REDUCING VALVE APART first an d clenaed it did not see any thing wrong there so i put it back together .. then the tractor moved i drove it around all gears worked . went to use it the other day and same thing it wont engage . tried several times then it moved .. problem seems intermittent . im at aloss now dont now what else to try.. any help out there ? thanks. briman...
