L3010 has lost 4WD
   / L3010 has lost 4WD #1
Jim Taralli
Holliston, MA
John Deere 4720
My Kubota L3010 has lost the 4 wheel drive. It has the hydrostatic transmition and it sounds like the shifter is doing something when I listen at the case but no 4WD. Any ideas where I should start troubleshoot or looking?
   / L3010 has lost 4WD #2
Welcome Jim Taralli.
My first thought is that if your getting the sense that it's engaging at the case that your problem may be up front. Looks like there are a few couplings on the propeller shaft (from the case to the front axle).. did you hear anything sudden when it stopped working?
I'm trying to think simple and not traumatic, if the locking pin broke down for some reason, maybe the coupling disengaged. Not sure if that ever happens though.
Good luck.
   / L3010 has lost 4WD #3
Does the front drive shaft spin? Are you sure the linkage is moving correctly?
From the WSM the probable causes of front wheels not driven are"
1) Propeller shaft broken
2) Front wheel drive gears in transmission broken
3) Front differential gear broken
4) Shift fork broken
5) coupling displaced
Normally "broken" has a side kick of "expensive bad sounds" along with it. You didn't mention that so I would look more to #1,4,5 -->> AFTER making sure the linkage is actually working. It moves a gear on a splined shaft to mesh with transmission.
The propeller shaft can be replaced and the coupler inspected with 2 steps.
Slide the shaft cover after removing the screws (2 screws).
Tap out the spring on the coupler, then slide the coupler to the front.
jb
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
