L3010 rear tire width and 2-14 plow
   / L3010 rear tire width and 2-14 plow #1
troweller
Bronze Member
Kubota 3010, Farmall Cub
What is the maximum width between the rear tires on the Kubota L3010?
I know there is 48" on center, currently 52" on center, and there are two more, but do not what they are. I can't find my book. At the current 52" spacing, there is about 20" between drawbar and inside of right tire. I am going to widen the rear end as far as I can. The proper width between drawbar and inside right tire for a 2-14 plow is 25", and a 2-12 is 23". I remember looking at my book it stated that my tractor was rated at 2-12 plow.
Is a 2-14 plow too big for my tractor?
   / L3010 rear tire width and 2-14 plow #2
Isn't your L3010 around 25 PTO HP?
If it is then I don't think you will have a problem with either plow.
But I am sure someone more experienced than I could tell you for sure
   / L3010 rear tire width and 2-14 plow #3
Hi Troweller,
You should have no problem plowing with 2-14's depending on the soil conditions. I plowed with a L2900 and turf tires it was OK as long as it was not to damp then all I would do was spin. It was still fun. Good Luck. I have an old 2 bottom plow on steel wheels I want to try but haven't gotten it all broke free yet.
Neale
Scag Mower (A50324)
Scag Mower (A50324)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
