Rotary Cutter L3130 and 6' Rotary Cutter.
   / L3130 and 6' Rotary Cutter. #1
penokee
Platinum Member
Little Girl's Point (Lake Superior), MI
Ferguson TO-20 (sold to son-in-law), AC - H3 Crawler, L3130HST, (AC-WD w/Attachments - SOLD), 1984 Honda Big Red, Honda Foreman 4x4 w/plow
Anyone mowing with a Kubota L3130 and 6' Bush Hog Squealer?
Many threads on Bush hoging, but couldn't find anything with this specific combination. Currently use a 4' Squealer from my Fergie TO20, but need something wider then the L3130 tires.
penokee
   / L3130 and 6' Rotary Cutter. #2
I have a 60" woods medium duty behind an L3410. It has plenty of power for most things, but would get stressed with an additional foot of width. But I am charging down 2-3" trees most of the time. Normal brush, grass and such would probably be OK at 72". Worst case you have to go slow and take 1/2 cuts.
I have not heard any bad things about the squealer by the way.
jb
   / L3130 and 6' Rotary Cutter. #3
Using a Landpride 1872 72" rotary cutter on my L3130 GST without any issues. The key is if in thick brush, drop to a lower gear and vise versa. Have not powered out yet.
Thanks both for the replies. Plan to look for a 72' BUSH HOG.
penokee
   / L3130 and 6' Rotary Cutter. #5
You will do fine with a six foot for normal use as an industrial tired machine needs it to cover it's track.
   / L3130 and 6' Rotary Cutter. #6
I've done some mowing this summer with my 3130 GST and a 5' KingKutter. Cut 1" saplings without a problem, but when I get into thick, high grass I have to slow down and throttle up. I think in real thick, high grass, a 6' swipe would be too much for the 3130 PTO to handle, and you'd probably have to take a smaller chunk. But if you keep up with your mowing fairly regularly, I don't think you'll have any problems.
   / L3130 and 6' Rotary Cutter. #7
I have a L3130 and a 5 ft Bush Hog Squealer. It handles a 5 ft size easily. Im very certain that 6 ft would work just as well.
dwight
   / L3130 and 6' Rotary Cutter. #8
I have an L3130HST. Running through very dense 4'+ fescue is no problem at all for 5'. I borrowed a 6' KK a few weeks ago to give it a try & it was marginal....Had to slow things down a bit, motor started running a little hotter.
Note that I have few flat fields; mostly 3:1 and 4:1 slopes, and I have a HST that costs me a little PTO HP.
The exercise saved me a few hundred, as I learned that 6' was just a tad too much for my particular conditions. I take delivery of a new 5-footer tomorrow.
   / L3130 and 6' Rotary Cutter. #9
F=ma:
Welcome to TBN :D! Many of us do not have the luxury of "borrowing" "test" attachments so we have to trust the opinions and experiences of the readership. Thankfully the readership is generably honest :). Keep the posts coming. Jay
   / L3130 and 6' Rotary Cutter. #10
jbrumberg said:
F=ma:
Thanks! I happen to have a generous, and well-equiped, uncle across the street. Reckon I oughta buy him a cold one for the loaner/saving me from making a several-hundred dollar mistake.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
International 133 6 Row Cultivator (A50514)
International 133...
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
