L3130 front axle check bolt
   / L3130 front axle check bolt #1
3130 Man
My service manuel I bought said there were two front axle check bolts but I only have one where the fill plug is. Am i missing something? Just want to make sure I have right amount of fluid in.
   / L3130 front axle check bolt #2
There are two drain bolts.
   / L3130 front axle check bolt #3
By check bolts, are you referring to the bolt you remove that marks the "full" level of the front axle fluid, or the drain plugs at the bottom of the 4wd hubs?
There is only one bolt/hole for marking the fill level, and there are two drain plugs, one on each side of the axle, for draining fluid.
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
