L3130 GST Problem
   / L3130 GST Problem #1
zettajoe
Aptos, CA
Kubota 3130GST
Hi Everyone,
we have had our tractor for about 4 months now and have been using the heck out of it. Today though, while using the tractor, the trans just stop working. GST light came on, and getting different error messages depending on what gear I try to put the tractor in. Error 61 - 66. I looked in the manual, and it does really say much other than call the dealer. Its Saturday, they are closed for the weekend, the tractor is not in the greatest place. Is there anything I can do myself to get the thing running again?
   / L3130 GST Problem #2
zettajoe
The only thing I could suggest would be to check all of the wiring harness associated with the control box, controls and the transmission. Did you check the fuses?
Vernon
   / L3130 GST Problem #3
I too would check the wiring. On the left side and underneath the tractor you will find a metal gusset that is supposed to protect the wiring. The small weak gusset has been bent before, but the wires have never pulled out.
Also more wires are located above these toward the rear.
Anyway it sounds like it could be a wiring harness problem somewhere.
L3130 GST, 4WD
   / L3130 GST Problem #4
zettajoe,
According to my workshop manual error 61 is, Solenoid 1 failure (at reverse) with the probable causes as 1) Solenoid output terminal's voltage is out of specification. 2) Solenoid broken or short-circuited. 3) Wiring harness broken or short-circuited. 4) Grounding plate of solenoid in poor contact with chassis. Error 66 is Solenoid 5 (sub-range gear shift) failure. Error 66 has the same probable causes as does error 61. I think you should have the dealer check this problem. Is it under warranty??? I hope this helps.
Bill
   / L3130 GST Problem #5
zettajoe
If your L3130 is not under warranty and you are handy with a wrench and multi-meter, I could fax you the pages from the service manual to trouble shoot your error messages.
   / L3130 GST Problem
Hey Guys,
Thanks for the posts. I was bulldozing a bunch of brush, lots of stick and branches everywhere, so the wiring sounds like a good place to start. I am going to check it out tonight and let you know what I find.
Thanks.
   / L3130 GST Problem #7
The GST electrical connector is under the step-up side beneath the body below the GST lever like smitty mentioned, if a stick jammed it, it could have broken, loosened, or pulled out that connector which will cause the GST error you described.
I layered a couple of strips of heavy duty duct tape over that entire connector area and around the metal protector for it after I dislodged the GST connector a couple of time in heavy woods work. The duct tape helps to prevent inadvertent jamming of the wiring by errant branches and sticks. Haven't had that problem again since then.
   / L3130 GST Problem
Well, the tractor is working again! The problem was one of the wire connections had come disconnected. I even looked right at it the day it happened, but it looked like it was connected into something. Live and learn. Thanks for all the advise. This site is priceless.
Joe
   / L3130 GST Problem #9
Now you'll know what is going on next time this happens when your are roughing it. /forums/images/graemlins/wink.gif
   / L3130 GST Problem #10
Hey -- Glad you got it fixed. I'm going to have something made for mine this winter to protect the undercarriage. For now I'm probably going the duct tape route as Sky Pup did. I too push up brush and small trees. Saturday after I finished I looked under the tractor just to check and a stick about 1 1/2" in diameter had wedged under the front end of the tractror and pushed up the white metal plate under the radiator. No damage thank goodness. Until I get some kind of skid plate(s) I am trying to be extra careful.
Have a nice tractor day,
Smitty
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
2023 BOBCAT 776R SERIES SKID STEER (A51242)
2023 BOBCAT 776R...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
