l3400 oil capacity! !
   / l3400 oil capacity! ! #1
swampvol
SC
Kubota l3400HST TLB
No matter how warm I let her get before dropping the plugs, no matter how long I let her drain, I still can only get 5 quarts in!
The manual says 6 qts., but either the manual is wrong or my dipstick is.:mad:
   / l3400 oil capacity! ! #2
My WSM says 6 quarts with a filter change, If you are not changing the filter you are right on the money:thumbsup:
   / l3400 oil capacity! ! #3
Are you removing both of the drain plugs?
   / l3400 oil capacity! ! #4
Are you removing both drain plugs and filter??????????????
Yep. Both plugs, and a new kubota filter.
   / l3400 oil capacity! ! #7
I'm sure that you are aware that not all jugs of oil are 1 gallon any longer. Some are 5 quarts or 5+ quarts. Make sure that you did not use a 5 quart jug thinking it was a 4 quart jug. I did have a friend who made that mistake.
   / l3400 oil capacity! ! #8
When I bought my L3400 it showed overfull on the dipstick. I changed my oil a couple weeks ago and used a Kubota filter. I removed both drain plugs and let it drain completely. I put in exactly 6 quarts per the manual and like yours it shows overfull.
I am going to leave the 6 qurts in there. I thought it was just my tractor. Guess not. Brian
   / l3400 oil capacity! ! #9
This is exactly what happened when I did the first oil change on my L3400. I drained some out so it was correct on the dip stick.
Now when I change oil I put in 5 qts and then after running, I add until full.
   / l3400 oil capacity! ! #10
I am guessing the total to the full mark would be about 5 1/2 quarts? Brian
2016 JLG 2646ES 26ft Electric Scissor Lift (A50322)
2016 JLG 2646ES...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
TRUCKING INFO (A50775)
New Edco Hand 8" Post Hole Digger (A50774)
New Edco Hand 8"...
