L3430 or L3830?
/ L3430 or L3830? #1
crazyhorse
I have 10 acres (small horse farm) with pond and several paddocks. Will be snowblowing with rear blower long driveways and bushhogging paddocks. Will also need to periodically move round bales (up to 1000lbs each). Manure removal and spreading, etc. Which tractor would everybody recommend?
Thanks for your help!
/ L3430 or L3830? #2
I went with the L3430 with R4 tires....put the price difference towards the 723 FEL...don't let the dealer talk you into the 513 loader...it won't lift the hat off your head /forums/images/graemlins/blush.gif
I move round bales, mow with a 6 foot hog, dug the pad for the new shop building, cut the drive and spread the gravel on the drive, drilled the holes and installed about 4 miles of fence, etc...
Yes, I'm a happy lil camper...
GareyD
/ L3430 or L3830?
Hey Garey thanks for the input. How long have you had it?
/ L3430 or L3830? #4
I've had the 3430 a year the first of this month....250 hours and running strong /forums/images/graemlins/smile.gif
GareyD
/ L3430 or L3830? #5
You cant go wrong with either. I went with the 3830 w/723 fel, r-4's, etc...& i'm very impressed. I use my tractor to do sidework(bushhoggin', foodplots, rake&load hay,etc..). One piece of advice I can pass on is if you plan on towing your tractor, make sure you get a big enough trailer. I bought a new 18', 10,000lb trailer, & with the fel attached & bushhhog/disk on back, I'm really pressed for room.
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
(2) UNUSED 320/70R24 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2001 T/A 20FT Enclosed Trailer (A61569)
2001 T/A 20FT...
2015 Dodge Grand Caravan Van (A61569)
2015 Dodge Grand...
