L35 owners,(& anyone else) a question for you
   / L35 owners,(& anyone else) a question for you #1
irwin
Veteran Member
SE Conn
2004 Kubota L35TLB, '89' Cub Cadet 1541
...about greasing one of the zerks on the backhoe.
The lower swing pivot zerk has little room above it, no way can I get my cordless gun's fitting on it. Normally I'd use my slide on fitting (designed for similar situations) but the zerk is recessed too far, won't fit.
The previous owner obviously had trouble also, it's the only one that's mostly dry. I tried replacing the zerk with a 45' one, but due to the recess'd area when I tried to tightened up the 45' zerk it hits the rim making it useless.
Anyone have a link for a true grease gun fitting that's made to fit recessed zerks with no room?
My next thought is to put an adapter in the zerk's hole and screw a 90' zerk into that, but it makes little sense to me that Kubota designed something like this. It just needs to stand a half inch higher and I could fit the slide on fitting there. Been greasing zerks for over 30 years but haven't run into this before.
2007 Kubota L2800D Utility Tractor (A51691)
2007 Kubota L2800D...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
