L3750 Remote
   / L3750 Remote #1
tehillah1
Colorado
Kubota L3750
I have a Kubota L3750 with a front loader and hydraulic top-link and leveler cylinder on the rear. The rear hydraulics are run through a 4 spool valve body with one spool not in use. The other three spools control the 3pt, the top-link and the leveler cylinder.
I recently purchased a 3pt backhoe w/bobcat style quick disconnects. I need to set up a quick connect system to the rear of my tractor for this unit. How do I set up a seperate set of remotes for this? Can I use the hydraulics that are already there for the leveler cylinder? Is there a way to run the hydraulics off of the unsued spool in the valve body?
Any input would be appreciated.
2011 KENWORTH T800 (INOPERABLE) (A48992)
2011 KENWORTH T800...
Fisher Snow Plow (A49251)
Fisher Snow Plow...
2018 Ford F-150 Ext. Cab Pickup Truck (A46684)
2018 Ford F-150...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A46683)
2017 Mack GU713...
2000 Gal Tank (A49251)
