JimMorrissey
Veteran Member
L39 loader in \"excellent condition\"
The dealer was out yesterday to take a look at my loader. I had previously posted that it seemed like it was losing some of it's stated capability. This is not the case. It's operator error /forums/images/graemlins/wink.gif Turns out that the pressure is right on at 2750 PSI at about 2800 RPM. I believe the "problem" I was having was trying to lift huge boulders too far from the pivot point with my standard loader bucket. I knew this and think I was blind to the situation because I wanted that L39 to lift that rock no matter what! I'm certain that all will be well when I get some forks and have the ability to get an object in tight. Big rocks sticking out two feet or more definitely change the feel of the loader's ability as well as its actual ability. Not sure what the graph looks like, but I'd imagine it's a steep drop as the load grows further from the pivot point. The dealer also confirmed that the loader is simply not designed to lift the entire machine on its stabilizers. He said he knows of no TLB that can do that more than a few inches, which the L39 can do. Basically you're lifting the entire tractor. With the stabilizers up it easily lifts the front end without a whimper or hesitation.
While here they tightened up some hydro fittings and and replaced the two connections on the front hydraulic links, which were leaking.
All is well with the L39. /forums/images/graemlins/smile.gif
