Tires L4330
   / L4330 #1
tcmike
centrial NY
L4330
Hi Folks!
I have not been here in years but thought of TBN while researching a tire issue for my 2004 L4330dt. It has 8-16 R-1 front tires. They are too narrow and sink into soft ground especially with the bucket loaded. I need wider tires.
After a lot of research I found a R-1 tire that is wider but the same hight (diameter) as the 8-16.
The problem I have now is how do I find wider 16" wheels to fit the tires - lug pattern- off set of my tractor?
Anyone know of someone that makes wheels?
Sorry, I left the tire size home - I'll post it tomorrow.
Thank you.
Mike
   / L4330
The tire size I found is 280/70r16 Michelin Super 8L. I need a 9 inch rim.
   / L4330 #3
You need to 'start' your search with the known dimensions of your present wheel. Your factory rim is: 6 bolt hub
Bolt Circle 6"
Pilot Hole 4.625"
0 offset
5.5" wide...
I think you will have no problem finding that rim in 8 inch or 10 inch width.... KennyV
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
STORAGE FEES (A51222)
International 133 6 Row Cultivator (A50514)
International 133...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2006 CATERPILLAR D604S GENERATOR (A50854)
2006 CATERPILLAR...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
