L5450 PTO Clutch Repair
   / L5450 PTO Clutch Repair #1
RobbKiker
Kubota
Hi Fellas:
Have a L5450 with the separate PTO Clutch Handle. When the PTO is engaged and the hand clutch lowered it makes a noise like something is slapping while spinning.
While it is engaged, I bring the handle up slightly, but with the PTO still engaged, then the sound will stop. PTO works fine and spins the 6' Hog without a problem.
It would be great if anyone knows what the noise means..... If not, my big question is whether I have to split the tractor to get to this clutch assembly. According to a diagram I found on the net, this assembly is not part of the main Ever Clutch on my tractor. I have attached a copy of the diagram I found.
Any thoughts would be appreciated.
Regards
Robb
Thanks Dave. I have a copy of the WSM. Just thought someone may have some experience with this issue.
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
