L6060 Air Ride Seat - Conversion
   / L6060 Air Ride Seat - Conversion #1
HorsPower
Bronze Member
Clarksville, MD
Kubota L5740 HSTC-3 Grand
I am looking at purchasing a used L6060 that is not equipped with the factory option air ride seat. Can anyone tell me what would be involved with swapping out the factory spring seat with the air ride version? Doest the entire seat need to be replaced, or can just the air ride base be swapped in place of the original spring base?
Thanks!
   / L6060 Air Ride Seat - Conversion #2
My L4060 looks to have the full seat. Granmar tag on the back. Looking at thing it should just be bolts & plugging in the wiring harness. Harness for the seat sensor & another for the air pump. Not sure where the pump wiring may be stock, probably sitting there unplugged behind the pan stock. Worst case scenario you just power it off the cigarette lighter if there isn't any wiring as it doesn't pull much juice.
Given all other plugs & other parts including speakers are there already there even if you don't buy the radio I bet the seat is similar.
Fallon, thank you for the reply! Does the tag happen to indicate the model of the Grammer seat?
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2017 Chevrolet Silverado 1500 (A52377)
2017 Chevrolet...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
