Loader LA402 Loader
   / LA402 Loader #5
The manual lists the LA-402 weight as 617 lbs / 280 kg
It does not specify what is included in above weight.
In a separate spec. sheet it lists the bucket as 175lbs/ 79kg.
:laughing:sawdust beat me to it :laughing:
   / LA402 Loader
sawduster98 and easygo
Thanks so much for the info now I can calulate what weight of trailer I need to haul it
   / LA402 Loader #8
If the rear tires are loaded do not forget to add that too!!! The B-7800 has about 230lbs of beet-juice (rimguard) per rear tire.
A friend of mine almost ended up in a ditch trailering his L-4400. He added up tractor and loader weight but forgot about the loaded tires. Just the tractor and loader were around the limit for his pick-up and the additional 800-1000 lbs of liquid in the tires put it way over.
   / LA402 Loader #9
my float position does not stay in unless I hold it , is there a setting on the joy stick to cheeck?
   / LA402 Loader #10
On back side of valve there is a cap. Remove the cap. Screw inside has probably come loose. Be careful to catch all the parts if screw has come all the way off. Check all linkage to make sure no other screws have come loose.
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2012 RAM 5500 (A52472)
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
Aer Way Tillage Tool (A50514)
Aer Way Tillage...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
UNUSED AGT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SKID...
