LA513 Question
   / LA513 Question #1
Ben3130
Bronze Member
Southwest VA
Kubota L3130
Hi Everyone. Over the last year I've started hauling a lot of wood and light materials with my L3130, both for myself and for the in-laws. (It really is true when they say that you don't just marry your wife, but her whole family as well :) )
What I am finding is that I have to make quite a few trips with the standard 66" bucket for the LA513, and these light materials (split firewood, mulch, small debris) don't even come close to maxing out the loader capacity. So naturally I thought "maybe I should look into getting a light materials bucket". But to my dismay, when I looked on Kubota's website for information about the materials bucket for the LA513, it says that there isn't one! Apparently the materials bucket for the Grand L series is only spec'd for the LA723 and LA853 loaders.
Does anyone know why Kubota doesn't spec the materials bucket with the LA513? Is it a capacity thing? I'm assuming that since I have the QA feature, it should physically mount to my loader. Also, if I can't get one from Kubota, does anyone have a recommendation for another source?
Thanks in advance!
   / LA513 Question #2
Ok you want to get a lighter duty bucket??? Even if your hauling nothing that is going to be close to the limits of what you got now I cant really see how getting a lighter duty bucket would benifiet you. Its still going to carry the same amount of material and not really going to save you any wear and tear. Just going to cost you more to move the same stuff.
   / LA513 Question
If you look at the dimensions of the light materials bucket on Kubota's website, the capacity is a good deal more than the standard bucket that comes with the LA513. I don't want to get a lighter duty bucket that is the same size as my current bucket, I want to get a lighter duty bucket that is LARGER than my current bucket and is made for carrying larger amounts of light-weight materials. This way I can make fewer overall trips. Hope that helps.
   / LA513 Question #4
Ok I got cha, I bought some pallet forks and used them on my L3400 (traded it in for L400:D ) and I could haul alot more stuff , I could carry 5 RR ties with it no problem now it was a bit bouncy needed more counter weight besides the Rhino mower on the back. you might be able to gets some Clamps and some other steel to increase the sides make it deeper??
   / LA513 Question #5
Ok I got cha, I bought some pallet forks and used them on my L3400 (traded it in for L4400:D ) and I could haul alot more stuff , I could carry 5 RR ties with it no problem now it was a bit bouncy needed more counter weight besides the Rhino mower on the back. you might be able to gets some Clamps and some other steel to increase the sides make it deeper??
   / LA513 Question #6
   / LA513 Question
Thanks for the suggestions, I appreciate it. I have looked into getting a 3pt. carry all, and might do that either way. I've definitely got a set of QA forks on my list as well, but originally I thought a bucket would be more suited to my needs than forks.
Either way, I'm still curious as to why Kubota doesn't have a light materials bucket for the LA513 loader. It seems like a pretty common need for landscaping and general property maintenance.
   / LA513 Question #8
Purchase the QA forks and a carry all frame. Have eyelets welded to the bottom of the carry all frame and then use the QA forks to transport the carry all. I have a neighbor who uses this to transport wood. Very neat. He also has a frame kit (Sides and end)he uses on the carry all and uses it for other purposes as well. He says he can install the forks, pick up the carry all and be moving before he could hook up one side of a 3pt.
   / LA513 Question #9
To buy the Q-Tach for the loader would allow you to switch buckets easily and use any size bucket or pallet forks you would like.
   / LA513 Question #10
According to the Kubota L price list the L2236 72" light material bucket is available for the LA514 (L 40 series), can't possibly imagine why not for the LA513 on the L 30. I would say just get one, can't cost that much anyway. :D
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2018 FORD EXPEDITION (A51406)
2018 FORD...
