Comparison Ladder vs 2 link ladder chains
   / Ladder vs 2 link ladder chains #1
93Mustang
Chester County, PA
JD ##@)
Interested in opinions regarding 2 link vs general ladder chains. Have r4 tires and will be used on pavement so no vbar etc. Will be using on a hill so it seems obvious but reason I ask is that the 2 link is twice the cost... I assume general ladder will do less damage but also provide less traction?
Thank you - Dana
   / Ladder vs 2 link ladder chains #2
The problem is keeping the chains from falling between the lugs of the tires. The 2 link just give you more chances of having a cross chain stay on top of the lug. They make nicer chains that are made for pavement that will work with any type tire.
Thanks crazyal- do you have a make or type you recommend for pavement?
   / Ladder vs 2 link ladder chains #4
Any chain will mark pavement, if you spin your wheels!
The more links that contact the surface, the less chances of slippage.
" " " " the smoother the ride will be.
I have some paved drive, and yes slip the chains from time to time but then within a few weeks of spring thaw the dirt and crud kinda blends everything so I don't se the marks.
But then I don't paint my pave either nor do I wax my tractor.
   / Ladder vs 2 link ladder chains #5
Aquiline makes a chain for skid steers and tractors called the MPC. They say it doesn't damage pavement. They are a little pricey.
http://aquilinetirechains.com/AquilineBrochure_0510.pdf
There's another company out of Sweden or Norway that makes a line of tires chains that include a pavement chain but I can't remember the name. They have a distributor in New Hampshire and often ship chains to local dealers for free so that's the brand I went with (but what I got is too aggressive for pavement).
2014 Ford F-550 IMT 7500-30 7,500LBS Crane Service Truck (A46683)
2014 Ford F-550...
CAT 416F Backhoe (A43476)
CAT 416F Backhoe...
Schulte FX107 84in Rotary Cutter Attachment (A46683)
Schulte FX107 84in...
Case IH 455 Round Baler (A48561)
Case IH 455 Round...
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
Lockwood 30”x11’ Stinger Conveyor (A47369)
Lockwood 30”x11’...
