Land Pride FDR1660 Finish Mower Belt
   / Land Pride FDR1660 Finish Mower Belt #1
kenmissouri
Missouri
Kubota B2400
I have a two year old Land Pride FDR1660 finish mower. The first belt lasted two years and only went bad because I let it get too loose. Since then replacement belts have only lasted a month or two. The Land Pride dealer wants $62+ for his belt with a GENUINE Land Pride part number. Otherwise replacements can be had for as little as $18. The problem is they don't last. What's with a Kevlar belt anyway? Are they really that much stronger.
   / Land Pride FDR1660 Finish Mower Belt #2
I have a 1560 and one of the bearings went bad and started breaking belts. No fun buying those belts. I replaced it and its been good ever since. Even still, I always bush hog tall grass first.
Thanks for the bearing call. I'm not familiar with the 1560. I had thought mine would make more noise if a bearing was bad but maybe not, easy enough to check. I had an earlier mower, a Rhino, that never did require belt or bearing replacement in 8 years and 800+ hours. I'll check the bearings tonite.
   / Land Pride FDR1660 Finish Mower Belt #4
1560 is a 60" Land Pride rear discharge finish mower.
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
1997 GROVE TMS750B 50' TON CRANE (A51222)
1997 GROVE TMS750B...
Toro Workman Cart (A50322)
Toro Workman Cart...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
