Buying Advice Land Pride RCR1872 or Bush Hog SQ172 for L4400HST
   / Land Pride RCR1872 or Bush Hog SQ172 for L4400HST #1
lazy dog
Western TN
Kubota L4400HST
I have the option to purchase either one of these for a L4400HST. I will need to cut approximately 2 inch oak saplings in the process of reclaiming some patures and fields.
Which would be the better option for my needs?
Thank you!
   / Land Pride RCR1872 or Bush Hog SQ172 for L4400HST #2
Thank you!
wich shredder is purely a personal choice.but i like the bushhogg sq172.an i run a brushogg shredder.
   / Land Pride RCR1872 or Bush Hog SQ172 for L4400HST #3
Thank you!
There both very similar in specs.Are the prices the same ?
Do they both bring slip-clutches.By any chance would one of the two have a chain guard on it ?I own the sq172 but IMHO Landpride makes great products.
If prices the same these are things I would consider that would steer me one way or the other.
Boone
they are both slip clutches neither have chain gaurds have rubber guards.
The land pride is $100 more
   / Land Pride RCR1872 or Bush Hog SQ172 for L4400HST #5
In that case if it were me I'd get the SQ172.
Whichever one you decide to get make sure you get your 3 point pins with it and you check your gearbox oil before useing nomatter what the dealer tells you.
Play safe TRACTOR UP !
Boone
Thank you very much for all of your insight!
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A50324)
2004 Fleetwood...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
2021 Keystone RV Passport 3221BH 36FT T/A Travel Trailer (A50324)
2021 Keystone RV...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
